6 inch leaf springs 93 explorer
onewyr
I have a 93 explorer and it has a SOA lift in the rear and i want to know if anyone sells an actual 6" lift spring for this truck. The factory springs that the installed over axle are worn out. Any help would be greatly appreciated
I'm also thinking about taking the crappy plate lift and coil spacers out of the front and installing 6" skyjacker brackets and some new 6" coils in the front any recommendations for the coils?
I'm not aware of any actual 6" lift Explorer leaf springs (I take it you want to convert it back to SUA?)
6" lift Ranger springs will fit if you turn the centerpins over, though on a Ex they're only good for about 4" lift (extended shackles can make up for that difference though).
Skyjacker's coils are among the best of what's out there, however it's not uncommon for them to sit a little low on heavier trucks (requiring shims or a spacer for full lift height, unfortunately they don't have different coils for different truck models).
