pmer
- Oct 4, 2012
I recently purchased a 1994 ranger with a manual 5 spd transmission(m5r1). Everything was working fine until on the way to work it malfunctioned and I had it towed home.
Pulled the transmission, took it apart.
Found the pocket bearing between the input shaft and the main shaft destroyed, almost fusing the 2 shafts together. It was stuck in 4th gear. Guess the previous owner let it run out of oil.
Got the ends of the 2 shafts cleaned up. Replaced the bearing, replaced the seals and put everything back together. Installed a new clutch/pressure plate and clutch slave cylindar.
Reinstalled the transmission and it will not shift into 5th on the fly. Shifts into everything else.
Since everything else is working correctly, I would have to assume (we all know about assumptions) that the problem is localized to the 5th gear/reverse part of the transmission.
Not sure what to do now, or what to check.
Any ideas/help would be greatly appreciated.
