eltigra306
I am looking for information on rebuilding the trans on my '87 4x4. I am fairly sure that the trans is the tk based on the stamped steel bottom cover. The questions I have are related to the od gear. There is only about 250 rpm drop between the 4th and 5 th gear drop and I was wondering if its possible to change the 5th gear to a better ratio for better fuel milage/lower rpm cruising. also I am wondering if there is a better set of bearings and sincros that I should look at getting for the rebuild.
While I am here I also have a question about my 4x4. It seams that when I get back onto pavement and don't stop completely when I take the t case out of gear something will jump or bang at about 45 to 50 mph, seams to be coming from t case or drivers side hub. Any ideas as to where to look while I have the trans out.
Thanks for any help that you can give.
