I have searched however, while driving(outside temp doesn't matter engine temp doesn't matter) between the speeds of 56 to 64mph my ranger will start to skip/miss when I try to accelerate the skipping gets worse and turns into a bucking feeling almost as if it is loosing fuel. Driving at 54mph and below and 66mph and above I do not have this problem. I am thinking MAF or TPS? BTW this is on my 99 3.0 flexfuel ext cab auto. 2wd ranger130,000 miles...I recently replaced the plugs and wires(motorcraft) and coil pack(autozone). It was running like dirt when cold prior to this and I searched and found a hose missing from egr area to the pulse sensor. now it runs like a champ except between the speeds as stated above...I have not replaced the fuel filter yet...but...something like that should be constant this is at any rpm just between those certain speeds. only codes (DTC) are lean banks 1 and 2.
Thanks in advance for any and all help.
