ChuckRanger
Hi,
I apologize in advance if this is previously covered territory. (it seems like almost EVERYthing is - but there's soooo much to search!)...
Anyways.... I just wonder what the possibilities are. It's at a tranny shop and they're going to check it out - but it appears obvious that often people here know more than the shop guys do, so I want to be able to point them in possible directions...???
This morning the transmission was slipping BADLY in reverse - even on flat ground. Tonight, when I went to drop it off, - not so bad.... Everything else seems to work fine... what would cause intermittent slipping?
I've seen things here on the EPC - and is "reverse band" adjustable? - any other thoughts?...
Thanks in advance!
Thanks in advance!
