So shane ur saying all the guys in the GMQ group. cougar group & f-150 are wrong. You can put a HO ecu on a non-HO motor the firing order would be wrong. car would not run right unless you put a HO cam into the non-HO motor to wrk with that ecu.
AS for SD HO or MAF HO. Just to be cost effective I would think the SD HO ecu is a better choice for kmalcom
MAF ecu 100.oo, to rewire to put a MAF plug in 25.oo. A MAF meter 20.oo from salvage yard
SD HO ecu 30.oo to 50.oo. a lil time to movie a few wires.. DONE.
But I still think leave it non-HO & get a f-150 ecu over his GMQ one. If he wants to up te power a bit the rockers will help. But think he not care for performance hp. But tq for the climbs & trails or towwing
I understand all the batch fire & that you can repin. But my point is why go threw so much headache to rewire like i said before.
Also the A9L is better than the A9P in a 5spd stang. So IF he does rewire to go MAF HO ecu I would think the A9L would be a better pick. I am looking at this as cost effective & simplicity.
Plus before I would do all the re pinning wrk, I would think of a non-HO is 155hp & if put a HO cam in your up to 200hp. So why not get a cam. Then either of the HO ecu in there.
Oh.. the link i have had in my book marks for a few yrs. I know the site..
Plus a side note. WOW.. Like the build thread on the pony.. SWEET.
The A9P is pretty dang good in a 5 speed Stang. The timing advances quicker, and that really is the biggest difference between the A9P and A9L. One of these days, I'll finally find an A9P for a decent price, and it's going in the Stang. It was very noticeable in the two MAF AOD to T5 swaps I've done. Here's a spark table - if you notice, the A9P has an extra 10 degrees of timing advance right off the bat. The X3Z is the ECU used in the 93 Cobra.
A9L
RPM______0____0____1,000___1,800___2,150___2,600___3,500___5,000___16,384
Degrees___8____8_____8______18.5____21.5____22.5_____22______25_____25
A9P
RPM_______0____0____0______1,600___2,250____2,600___3,500___5,000___16,384
Degrees___18____18____18_____18______22______23______22______26______26
X3Z
