5.0 motor questions
dutinsss
these are probably going to be some dumb questions, but i'm not up on my ford motors like i should be haha. i have an '88 bronco II and i want to do a 5.0 swap. the key point in this is going to be simplicity, so i want a carborator, mechanical fuel pump, as little wiring as possible, etc. i have a few motors available from some friends but i need to know if any 5.0 is as good as any other 5.0. basically, can a mountaineer efi motor be converted to distributer, carb, mech fuel pump and all that easily and cheaply. most of the motors i find are out of mountaineers or explorers. thanks for any help!
All you need to do is replace the intake setup with a carbed intake and replace the cam sensor stub with a distributor that's got a steel cam gear to match the roller cam. I would also replace the stock rockers with 1.7 ratio full rollers. That'll free up about 15 more horses. The Explorer/Mountaineer's got a good cam, just needs a little help from some more lift. Best cam I've ever run with a carb for daily driving.
ok cool. what will i need to do for a mechanical fuel pump? and what all will i need besides a distributer for ignition?
For a mechanical fuel pump I think you have to go with an early ford van pump because they are upside down. A standard pump will have clearance issues. Honestly a decent electric pump is a better choice. They are simple to install and all you really would need is a regulator.
ok, i might go electric but i want to keep it as simple and easy to work on as possible. which i know electric pumps aren't too bad so i'll consider it.
exactly, and you might have to swap the timing covers for one with mech pump provisions.
so what i'm i going to need as for as ignition goes?
rebuilt duraspak dist. for an 85 5.0 mustang with 4bbl (not CFI)... it will have the correct gear and plug right upto a blue grommet duraspark module and the correct coil.
dizzy (parts store)
ignition module (parts store)
coil (parts store)
duraspark harness (junk yard)
that should take care of it... the new parts shouldnt come to more than$100.00 if you have an old dizzy for a core (most part guys wont know the difference... take any SBF dizzy for a core). :icon_thumby:
Not ""might" here in this case. To run a mech fuel pump you WILL have to swap the timing cover, plus the rest of the front end accessory drive setup. It will be much simpler to run something like a Mr.Gasket 12D electric pump to feed the carb. Two wire hookup (one hot, one ground) wired into the ignition hot wire. And run that thru the factory impact kill switch for safety. No regulator needed for this pump, it's a 4-7 psi with a 30 gal/hr flow. Plenty to run three carbs at WOT.
DUI (Davis unified ignition). It is a GM HEI based ignition system that is made to fit a 302. All you need is ignition power.
A lot of people don't like the idea of a chevy distributor on their Ford though.
x's 2... the explorer acces. drive set is shorter than earlier models, giving more room for cooling fans, so you want to keep it, if you are not determined to have a mech pump. the Mr.G pump will work fine... one thing i would add is, USE A RELAY! for sure.
where would i find info on the DUI setup? i'm down for anything that is cheap and simple. now that i know i'd have to swap my whole accessory drive, i think i'll look into that electric pump.
Try searching Ebay for "Ford HEI". That's how I found mine. :yahoo:
he never said it was cheap... ford duraspark is cheaper, plus you can get parts at any parts house... good luck finding DUI parts at a local autozone (in stock).
i guess i am biased... i hate bankrupt automakers (chevy)! :icon_rofl:
