5.0 Manual swap- 2002- Hurdles
The f150 transfer case is a TIGHT fit in a ranger, but it can be done. My truck is a 2001 and it really doesn't care that I removed and replaced the ECU with a megasquirt. PATS is inside the ECU, so if you remove it, you also remove PATS.
You have any pics of the tcase fitment? I'm gonna go with the 302 on account of the AC bit, but again, haven't quite figured out the computer.
I have no idea if an explorer harness would even plug up to a truck/foxbody ECU to begin with- if it's a few pin swaps here and there, good deal, but if the plug is completely different, that's a whole nother level of "nuh uh."
Not to mention, the Explorer 302 is coil pack ignition and most of the 302s that had manual options came with distributors (if I interpret the junkyard pictures correctly.) That is obviously not something I want to break by swapping an ecu.
What are my options for dealing with that? (running an explorer motor to keep coil pack ignition and still being able to run a manual)
JY would be best place, most aftermarket ones I have found are set up for the smaller starter.
Here is a write up I did on it awhile ago:
The mod is you basically dremel the starter hole slightly bigger, not much to take a picture of.
You should really look at the differences between the 1356 T case and 4406 T case, if I remember right the offset is like 3" more on the 1356 that would be in a 5L F150 which would put it deeper into the frame rail and below the frame, if you're planning on sticking with the stock axles that could be an issue.
The f150 transfer case is a TIGHT fit in a ranger, but it can be done. My truck is a 2001 and it really doesn't care that I removed and replaced the ECU with a megasquirt. PATS is inside the ECU, so if you remove it, you also remove PATS. 351W is a taller deck and interferes with the A/C box primarily. If you are planning on forced induction, I would recommend just building the cheapest junkyard engine you can find. 302 parts are dirt cheap and you can get a full balanced rotating assembly with forged pistons for around 1500 dollars.
351W being taller deck, is both taller and wider; there is significant interference with HVAC box (even the 5.0 has some), it gets "snug" with the steering column and makes for challenges with exhaust manifolds/headers.
Later 5.0 blocks (80s and newer, as opposed to 302 blocks from 60s) will only make about 450 hp before the integrity of the block comes into question. The Mustang boys would split their blocks in 1/2 when exceeding.
What is your plan down the road for the fuel injection system when you eventually go with a blower or turbo? I am thinking a stock computer is going to need modification to handle any boost. You are hung up on the anti-theft thing but I would look into the future as to what computer is going to be the best for your final boosted engine goal, and possibly plan on that now if it's not too expensive.
