Just an update as I cleaned my Tcase motor over Christmas. It didn't look all that dirty inside but there was some slight contaminates/dirt/crud on the armature from the brushes. I mean slight, I thought, this is what has gotten me stuck in snow, mud, wet grass, ect... for years? I hate this stupid motor!
I debated putting die electric grease on the brushes/armature. But I thought to myself, if a little black stuff causes me this much trouble, what woudl the greae do? So I didn't put any on.
Just be sure to remove the one wire pin in the connector when removign it. I chose not to cut mine. My connector looked clean too, no corrosion in it.
I did break off one of the two bolts that holds the Tcase motor pieces together. I was just the end where the two nuts are on the bracket. So the motor is held together fine, just teh bracket only has one nut holding it to the motor...
I will fix it with a new bolt/stud/all thread next time I am under there.
The stop inside the gear was ok too, no problems there. I made sure to use silacone on all the seams putting it all back together. Now it works like a dream. We will see how it fares after the next water crossing/mud hole.
