4x4 will light up but not engage?
Ranger Business
i have an automatic 4 wheel drive push knob and when i turn the knob to 4 hi it will light up like it is on but it will not engage into 4 wheel drive. when i put it in neutral and step on the brake and put it in 4 low it will clunk like it transfers in but then i will drive around and it will not be in 4 wheel drive? the light are not blinking and i checked the #27 fuse and its good? my front driverside hub blew out about 6 months ago and i got it replaced at ford. could this have anything to do with the problem? thank you!
is your front driveshaft spinning or no? My first guess would be the hubs. Especailly with those !@#$in pulse vacuum hubs.
yeah, you may have a vacuum leak, or another bad hub.....
if ya hear it "clunk" into 4 lo, i would say 99% sure it is the hubs...
worse case scenario is ya blew your front ring and pinion or spiders
l8r, John
