4x4 ranger problems
fordranger98
4 wheel drive doesn't work shows its in 4x4 but not engaging what can i do?
thanks bill
transfer case shift motor
GEM
vacuum actuated hub system
98 ranger = vacumn hubs, good replacement is avm hubs
check fuses, push BOTH brake and clutch when changing the switch (4hi to 4lo specifically), check the hubs for vac leaks, replace with AVM manual hubs (I did),
BTW, how did you confirmed non-working 4wd? The front is open diff from factory, most of the time. If you engage the hubs and hand turn the lifted off the ground wheels and see the same side axle turn, it is locked in... Otherwise, you have hub problems. Check the Tech articles, they have lots of info.
