Where, online, can I get t-case linkage bushing?
Yes, the cam plate is definitely the same as (or at least an integral part of) the lever bracket. This page has the diagrams I am talking about that I had also seen in my chiltons or haynes.
http://www.broncoiicorral.com/2wd_to_4wd.htm Ignorant folks like me can't tell what/where the heck the cam plate is in the adjustment procedure diagram when the main diagram calls it the lever bracket. Mine's modified and missing the neutral lug, so I first thought maybe I was missing the cam plate.
I did get underneath to have a look, but was temporarily thwarted by the wierd non-nuts that attach to the bolts that hold the little skid plate on. Driveway is too muddy to use ramps or jacks, so couldn't really see them, but could feel maleable, flat squares that maybe used to be welded in place? They are so thin, it seemed like they might be designed to give and tear away to minimize frame damage by letting the plate slide away if impacted hard enough?? They were spinning freely and I couldn't get a grip on them with the few tools I had under there with me. Will wrangle them off with vice grips or hack saw the bolts soon, but wonder if anybody has a special trick for dealing with these...?
I could see enough of the t-case assembly to tell the linkages were modified qite a bit by the builder of my rig. Not looking forward to trying to remove the big bolt as it is pretty crusty-rusty - it looks like it came from a deep-sea wreck.
No bushing left at all. Anyone know where to buy online? Can't seem to find them.
Haven't cut and JB welded a new neutral lug, but did notice I can not pull it down from 2H to neutral when I try to while at a stop with with A4ld shifter in D or 2. So, not sure why or how it is slipping into neutral when I'm driving up a steep hill (though it hasn't done it the last four trips up the mountain). I think I will try working on the linkages, etc. first. I did notice that the whole assembly kind of torques up and moves quite a bit when I shift the AT. Anyway, I plan to dig in, lube linkages, replace bushing, and try to tighten it all up soon.
I did have success with the side-note issue of the AT shifter hitting the bottom of the plastic indicator bezel before I could get it into 1st gear (while also being maxed out at top for P). When I had the bezel/indicator up again, I cleaned out some of the carpet build up, tightened the bolt/spring assy at the base of the stick, and then just didn't screw the bezel back down so tight. It's pretty darn tight, but has just a tiny bit of play so that now I have a really distinct Park and, yay! - I have 1st gear. No more riding the brakes down the mountain when crawling in traffic.
