4x4 lights flashing?
DeanCampbell
i put a 3'' body lift in today then drove home from a buddies and notiched my 4x4 and 4x4 low lights were flashing, they do it about 5 times then stop for a mintue then flash again?? any ideas?
Well count the flashes... Its a simple code. Like if it flashes 5 times then stops then flashes 3 times or something like that.
For example when I drive my truck the airbag light will flash the code 7 - 2 (seven flashes then a pause and then two flashes and a pause) it means the airbag computer is bad or there is a loose wire.
I bet anything though it means something got unplugged when you lifted it. Check your T case plugs and see if any came out or look stressed.
yeap checked yesterday turns out a plug on the tc was unplugged, so i had to pull out those push plastic holder things and cleaned it out with sum contact cleaner plugged it back in then unhooked my battery for about 5 mins, then plugged it back in and shes good now! thanks
