4x4 coil springs
tmar04
will B2 4x4 springs, installed on 2x4 B2, give me any more lift? Looking for about 2 in more to use 235-75x15 tires. thanks
I didn't think the 2wd B2s sat any lower. At any rate, I don't think you'll have any problem fitting 235/75-15s.
if you need any clearance you it would only be a little.. I'd do the washer under the coil spring trick.. i think its in the tech library here
how many washers would I need to get 2 in lift? thanks.
2 inches worth of washers.
Washers:
http://www.therangerstation.com/tech_library/WasherCoilSpacers.htm
you shouldnt need any lift for 235/75r15's. i have 31's on my b2 with no lift and no rubbing. before i put the 31's on it had the 235's and they looked kinda small
