4x4 brackets on 2wd for lift
red_ranger93
ontario
i was curious if they are longer and i know the drivers side one would be backwards on the 2wd set up but that is a easy fix just wanted to know if they work thanks.
I believe the bracket (for the driverside beam) is the same height, but the passengerside beam itself is a different length than for a 4x4. Not going to fit properly if you use a 4x4 bracket.
Most of a 4x4's lift comes from the shape of the beams,
not the brackets or springs....
AD
