I am not sure exactly what you mean, but.. You can't bolt the transfer case to a 2 wheel drive transmission, you need to have a 4x4 transmission with the correct output. Unless you were to swap parts between the 2wd and 4wd trannys.
2wd and 4wd transmissions have different output shafts. If you want to convert a 4wd trans to a 2wd trans (or vice-versa) you need to swap output shafts. Which involves disassembling the entire transmission.
For
