4wd rear blocks on a 8.8" swap
jefferzbooboo
I'm going to be swapping an Explorer 8.8 rear end this weekend. I plan on using the Explorer leaf spring as well.
I want a little bit more lift in the back and I've seen that you can use the 4x4 rear blocks to lift the rear end an extra 2".
A local shop said they could bend me up 2" longer 3 1/4" u-bolts.
Is there any reason I couldn't use the 2" rear blocks?
As long as you flip the perches on the axle you can use them. The expo leafs will give you some lift as it is.
Sent from my SM-N920V using Tapatalk
