peganit2
- Oct 11, 2015
- Automatic
Your brake lights wouldn't work if that was the case for that switch.
And your starter motor wouldn't work if Trans Neutral switch(NSS) wasn't working.
But yes, the Ranger(and all Ford trucks) column shifter's have weak points that cause them to loosen up.
Google: Ford Ranger column shifter
The most common issue is a couple of screws that loosen up and even fall out causing shifter issues, this is an under the dash issue.
I had this '98 4WD shift control diagram, will be the same as '97:
EDIT, it won't let me post ir here because it is already posted in another thread.
Go here, post #4: http://www.therangerstation.com/forums/showthread.php?t=162915
My 96 Windstar had shifter issues that turned out to be no more than a couple of loose screws, plus the two holding the shifter on...
I haven't tried to start the Ranger in neutral though...
Thanks for the Diagram Ron, you are, a reasonable man.
