- Nov 5, 2007
- Manual
No, no. A blinking LED means it's good -- from the page:
http://www.therangerstation.com/forums/showthread.php?t=97
2. If all the fuses are good, the next step is to run the 4x4 module self diagnostic. The 4x4 module is located behind the driver’s side rear jump seat on super-cab models, but as far as the other locations I don’t really know. This module will have three connectors going to it – one will be a pig tail, the other two will be located on the right side of it (side towards the front of the truck). These two connectors must be removed to diagnose the module. With the key in the off position, remove these two connectors from the module. Next, turn the key on with the engine off. On top of the module is a white rectangular button located next to a red LED….push the button and watch the LED.
a. If it flashes, this indicates the module is working properly. Go to the next step
