Kyallroad
- Aug 16, 2015
So, new member here and I hope this makes sense as I post it.
The 4wd system on the '94 Ranger does not engage. Today I set out to find out why. Things I've found so far include: transfer case actuator motor engages and turns 90 degrees. But then turns back to it's "rest" position. When 4wd engages it spins the front drive shaft and the front axle but the hubs do not engage. I removed the drivers side wheel and outer hub to find that the "grease" is more solid than lubricating so I started cleaning it out but stopped at this point. I think I need a special great big socket to remove the front hub nut to properly clean and regrease everything. But at this point I don't even know if the hubs work. How tough is a transfer to manually locking hubs? And any ideas about the 4wd actuator? At no time does the light come on saying that 4wd is engaged so I'm not sure where to go with it.
Thanks in advance all.
