4L80E trans replace. Help? Turbo Swap?
BronKitis
TRS Banner 2012-2015
Spanaway, WA
I have a 1992 K2500 with the 6.5 Diesel Turbo. Last week my tranny went out. I found a tranny/tcase combo with less than 50K for 600 bucks. I have replaced 6 Manual transmissions but never an auto nor do I know much about them. I geuss my main concern with this task would be the torque converter removal/install and the wiring. Has anyone replaced one of these with tips they'd like to share? Any help is greatly appreciated.
Also, the motor is pushing 180K. I have access to a 1999 Dodge 24V Cummins turbo I am thinking of installing for a little more boost. Stock she only pushes around 9lbs and the Cummins should push between 12 and 14lbs (right?). Would this be too muich for my ol' diesel? She does have a high compression ratio and don't want to hurt her but theres not much out there for my year. No chips offered until 94' :( Thanks for all the help I hope to recieve ;)
AJ
I would skip the dodge turbo. it has been played with and has been found dangerous for a 6.5..... that cummins turbo will boost alot higher than 14 psi.
I would change the injectors and do head gaskets before you rack up to many more miles, you are right at the limit for the injectors and the head gaskets (most fail around 200K for the gaskets, and injectors should be changed around every 100K)
I would go to www.thetruckstop.us and check out the 6.5 performance section. There are quite a few things you can do (most of them cheap) to a 92 and a 93.
Head gaskets scare me :( But I shoul do them before they go. Thanks for the tips. I will be checking that website out asap. May just pull the motor with the tranny and do it all at once. How many miles on your 6.5?
200198, just looked at 1 hour ago. I cheaped out on the injectors so now i need an engine (blew a piston), but mine was screwed ..... cracked heads, crack in the #8 cylinder wall, crack in the main saddle from the register to the cam journal...... the replacement 6.2L was also cracked on the same main in the same manner....... My engine had been over heated ...... probaly would have been fine if I hadn't blown the injector and piston.
I am still searching for a block.
You're starting to scare me. I think I've got a good one though. She runs amazingy well and has been very well maintained. Looks almost new under the hood. Run nothing but Delo 400. Fires every morning with no issues. Little bit of smoke now but She also needs some new plugs....
Where you located? May know of a good running 6.5 TD. 116K miles, buddy totalled it about 6 mos. ago.
AJ
in my case it was cheap injectors and having been over heated in the past..... cracking is common....... if yours is the original engine then its a 599 block...... thats the strongest GM casting you can get ...... if you do the gaskets and injectors and glow plugs that engine will last a while
