v6supercharged
Hi ! first i speak very bad english ! im new owner of a rough country 4'' #7540 kit for my 97' ranger 4x4 xlt ... i already have a 2'' lift and a 3''pa body lift ... but i have a problem when i try to install the rear of this kit ... the u-bolt are not enought long ... y put my 3'' block + my stock block ... but i dont have enought tread ....
update i look on the box and i have the #7542 Block and U-Bolt Kit (Bronco II) but i need the #6546 Block and U-Bolt Kit (Ranger) ... can someone there know the difference between this 2 rear kit ??? i will do the modification for ... is it normal to add the new block + the stock one ?? ....
another question : can add with this kit my 2'' lift ?? puck in coil spring and the add leaf ??
thank you very much !!!!!!
