TroyM
- Nov 26, 2008
- Automatic
93 ford ranger 4 litre 5 speed
problem: engine loses power between 1000-3000 ish RPM.
what i have done: cleaned the K&N filter, installed new fuel filter, checked cat converter, it is good. I have cleaned the MAF sensor with the MAF Cleaner.
when it happens: on any startup, whether cold or hot, it runs perfect for about 20 seconds with lots of power, then after that it feels gutless and sounds like its wanting to go but cant. If i turn the key off while driving, then turn it back on, it will be good again. Then after 20 seconds of driving again it starts losing power.
so what is it? MAF sensor needs replacing or o2 sensors, fuel pressure regulator?
thanks.
thanks.
