yup.i use that for panhard bars and such all the time,it's pretty strong.if you use chevy leaf spring bushings the o/d is 1 1/2,so some 2" .250 wall dom makes good bushing sleeves.energy suspension's p/n is 3.2106g.
i wouldn't think you could even do a triangulated 4 link on a TTB - the engine and crossmember would be in the way of the upper links.
Gwaii's setup looks like the best possible setup for a TTB.
a triangulated 4 link would serve no purpose in a ttb...the triangulation is for lateral positioning,in the ttb this is done by the arm mounts,so i don't even know where the idea for this came from.
and try to keep the wheels from cambering
i would stay away from heims-i don't know how it is in your region,but here heims are illegal on street vehicles,if the cops see them they'll pull the truck off the road.urethane bushings give a better ride,and last longer so i'd be inclined to use them.
Not actually true Tom:
RE: Heim Joints, Rod Ends
Vehicles built with this type of suspension, steering and other linkages shall have these linkages inspected for structural integrity as intended by design, Ensuring that these joints/linkages are not modified, installed properly without binding, have locking nuts/devices in place when required, and that they are of recognized manufacturer
If these joint and rod ends meet the above installation criteria the vehicle shall not be rejected for having heim jounts or rod ends installed.
Please note that the same joint or rode ends that has been modified, welded upon, not having locking nuts or similar devices and improperly installed, IE with a bolt through a tapered hole shall be REJECTED.
this is keeping with the industry norms for aftermarket suspenison and steering components manufactured by recognized manufacturers.
Curious... is that published some place? I was always under the impression that use of heims etc. was frowned upon.![]()
hmmm....makes sense,especially about modifying them.
i wish i had this info a few years back.sometimes it seems you need to pack around a copy of the motor vehicle act to protect yourself.
but it doesn't look like a cobbled together POS either...
