notched cross pins are $HIT, they suck and are known to break. Use your stock cross pin, and just shave a little off the ring gear, you dont have to remove much. Install your ring gear, and you will see exactly how little youll need to remove to be able to slide it in. I used a 4.5 " grinder
For
