4.10 in ranger
Focklerx33
Belleview Fl
did the 7.5 on the 4wd's come with 4.10 stock. on the tag the first numbers are a 10? dose that mean its 4.10 years
The door sticker has the axle code on it just get the code and find it in the axle section.
Yes, the 7.5 came stock with 4.10
Sometimes the first number is hard to read. IIRC on the tag bolted to the rear end cover, hole to the left, the ratio numbers are on the lower left. If you can see a 4, space, followed by a L10 - you have a limited slip w/ 4.10 ratio, a 4, space, followed by a 10 - you have a open 4.10 ratio.
Richard
4.10 gears in 7.5" Ranger axles are actually not all that uncommon in 1983-89 Rangers/Bronco2s
But one thing you will never (ever) find is factory 4.10's behind a 2.8/2.9 and a MANUAL transmission.
And yes, the "4" often hides under the head of the diff cover bolt that holds the tag to the axle.
BTW, if the Tag reads 4L10 plan on replacing (as a unit) the limited slip you find inside
if when you remove the cover you find several coil springs.
The Borg Warner limited slip unit is an absolute POS.
Though many were replaed under warranty after their abrubt and catastrophic failure
with "S-spring" ford built Traction-Lock units.
If OTOH your tag is reads: 4SL10 that means you have the later Ford built Traction Lock "S-spring" limited slip differential, which CAN be rebuilt (a clutch kit is ~$70)
AD
