oldfaithful
Hello All,
I've been using this forum for quite some time as a technical resource, and let me say that it's been GREAT! Thanks!
There is 1 item that I'm having trouble finding throughout my many searches, so I"m posting this question. If its been posted already, but I've missed it, please feel free to just direct me there and delete this post.
I have a '97 Mazda B4000 4X4 with the 4.0L, M5OD-R1 transmission & 3.73L gears. It runs fine, but seems to lack the proper gearing in 1st or 2nd. I'm content with the rear gear since it cruises the interstate just fine, and I don't want to push the RPMs any higher while cruising. It just has no torque in 1st gear and has always seemed like it requires a bit more clutch to engage 1st than I like. The specs say that 1st is 3.40 and that's what I'd like to change. I've read that it's possible to swap another M5OD from a 2.9, which would have the alternate gear ratios (3.72 for 1st).
A) Is this a good swap?
B) Is there a better way to improve (aka lower) 1st & 2nd gear?
C) Will the donor M5OD from the 2.9 have to be from a 4X4, or can I swap the tail and TC onto a 2WD transmission?
D) What years/models should I be looking for?
Thanks in advance!
Thanks in advance!
