4.0L Flywheel - Manual Trans
belovedb2
I am doing the 4.0L Swap and am using a 4.0L with auto trans but putting it in a manal B2. I plan to upgrade to the 10 inch clutch. Do I need a different flywheel or can I use the flywheel from the 4.0L auto engine?
manual and auto fly wheels are different. You will need a new flywheel.
You will need a 4.0 Manual Flywheel, Clutch and Starter.
an auto tranny doesn't have a flywheel. its a flexplate. the torque converter bolts to it. the manual tranny's need a flywheel. and the clutch/pressureplate bolts to it.
they had two different flywheels as well. a six and an eight bolt. make sure you get the correct one!
HEY!!! I was going to say that.:icon_thumby:
