rickcdewitt
any one put an auto tranny cammed motor in a 5 speed truck and notice much difference afterwards?the manual tranny cam is supposed to be advanced 10 degrees and i wondered it it makes the auto tranny cam softer on the top end?its probably not worth swapping cams in a used motor but i have a MT cam with 50,000 miles on it in really good shape that i could swap in.but then i think you'd need to replace the cam bearings if you swapped the cam.if the auto tranny cam had better bottom end torque then i think it would be a good compromise.what are you guyses thoughts?
