unoleisu
I've got a 97 expl XLT 2wd. When I bought it (winter, 08), it ran fine for a few weeks, then just quit starting. I replaced the MAF with a new one, and Temp. Sensor with new, also new plugs. It ran rough, and then died again. When I got it to start again after days of trying, I took it to Autozone and checked the codes.
Got P1151- lack of 02 switches, bank 2 sensor 1. ECM could not adjust because of lean or rich condition.
Probable causes: 1. fuel pressure high or low 2. MAF sensor dirty or defective 3. Vacuum leak on engine 4. leaking fuel injector or fuel pressure regulator
It ran fine thru the next summer then started acting up again. Took it back to autozone and scan test said 2,3, and 5 plugs misfiring. Replaced plugs and plugwires. Ran fine for a little while, then Started the same thing again. (only at first, I noted that it would not start only when the outside temp was under 50 deg. but ran fine in the 70's) It finely got to where it would not start and run at all.
Jan. 2010 I replaced TPS, IAC and Intake air sensor, as well as the O2 sensor at Bank2sensor 1
I tested the coils and harness and all passed according to the book. Found that the clips on the coil harness connector was broken and it was wire tied on, I made sure it was tight. After recharging the battery, It started and ran fine. Next day wouldn't start again. Checked the coil harness again, seemed fine and tight. Still no start.
I gave up and let it sit until june, 2010 trying occasionally to start it,Then finely towed it to a Mechanic, who kept it for 3 mths....
He said he fixed it. Replaced Battery, fuel filter, air filter, IAC, altrenator, Tested the fuel pressure, replaced the plugs, and finely disconnected the Stereo system (saying this was the REAL problem, it was shorting out).
The truck started up rough at the shop, but then leveled out, and ran fine on the way home. I went the next day to move it from my driveway to another spot, and it ran really rough, dying as i got it to the new spot. Can't get it to run again since then.
Today I tried to test the Crank position sensor, (since it seemed to me if this was an old car running like this, it might be timing) It seemed ok. The fuel pressure test port on the rail didn't seem to have much pressure when I depressed the "valve stem" only a little gas dribbled out. ( I thought it might have SOME pressure beyond that).
I'm obviuosly shooting into the dark here, and not getting any help from the mechanic.
Can anybody help a guy with no clues left?
