I just swapped a new 4.0 into my truck. I heard the motor run before I started the swap. I just tried to turn it on after many a words and thrown bolts only to have it idle up to about 3K RPM then it tries to die.
On the passenger side manifold the two middle bolts are stripped out on the head (I didn't do it). I figured this would give me an exhaust leak, but not enough of one for it to die.
I've tightened the collector bolts down as much as they would go, and the flanges seem to be pretty well seated.
When it does run, there exhaust smoke the comes up into the cab.
Any help is appreciated.
