Big Jim M
??? Who knows??
So no telling what you took off of there. It is a common thing for guys to take off partially stopped up mufflers and after replaceing them the guy THINKS the new parts all by themselves made the difference! OR he did a tune at the same time and the TUNE made the difference!
So you got what? 300rpm at a place were few dare to tread? Wooo Hooo!
Actually the cai did NOTHING for that ride. Actually the larger pipes prolly slowed down the engine and gets worse milage at NORMAL engine speeds.
There is a big difference in parts meant to be on the TRACK and parts that will survive on the street. If you put a 900 HP V-8 NASCAR engine on one of our lil trucks it WOULD NOT back out of the driveway! Much less get you to the grocery store.
I'm thinking most guys on here use their rides for everyday common driving and not the 1/4 mile! When speaking to THAT application, there are few if ANY modifications that WILL make the drive cheaper or more powerful..
In your case you seem to be real prowd of gaining 300 or so rpm at the top end.. MY RIDE hasn't seen five grand EVER! I LIKE it too much to run it up there..
Big JIm
Bone stock, 1st gear, pedal to the floor, my truck would NOT hit 5k RPM. After installing, a cold air style intake, 2.5" exhaust and Hi-flow cat's I can pull 5200 into 3rd gear, and the truck is noticebly peppier even though any mileage gains have been negated by weight and tire/lift.
Now, in addition to the little things like those I would do a cam swap (comp 422) and the head work as well as bumping the compression up. 95tm heads on your 90's 4.0L would be right around 10:1, and along with everything else would make for a fariy peppy 4.0L.
Big JIm
