Douginator
I’ve recently picked up my 2003 FX4 for $700 with a broken timing chain on the left head. When I pulled the motor to do the chains I found the usual broken guides and related debris in the oil pan which was thoroughly cleaned before installation. All valves were replaced while the motor was out. After I put everything back together the truck ran phenomenally for 14.2 miles, when my left hand timing chain broke. I had made the mistake of purchasing a cheap timing chain set, and ended up pulling the left head again and replacing the chain. Fortunately none of my valves had bent, so I put the engine back together with the only new parts being the left head gasket and timing chains on the front of the motor. I had doubts about the cheap timing chain set before I installed the motor, so I had purchased a cloyes cassette for the rear chain. All timing components besides the rear cassette were replaced with Melling parts. The job went back together without a hitch and the truck drove great for 300 miles when I started heading a ticking noise on the highway. I continued driving but for the next 15 miles the ticking got louder and louder until I lost oil pressure and I was forced to pull over. I checked the oil and found it to be clean and full. I would be able to drive the truck for a minute or so until it lost oil pressure, so I limped it nearby to a friends house. I did an oil change (with filter) and have not had an oil pressure issue since. At the same time I pulled both of valve covers in hopes I would find something in the top end to explain the knocking noise. Other than irregular wear on #6 exhaust cam lobe everything checked out. The irregular wear could be described as looking like graphite powder on the cam love. It didn’t seem likely that this would cause such a deep knock. To diagnose the noise as rod knock I pulled each spark plug wire until the noise got quieter. It seemed at the time that the noise almost disappeared when spark plug wire #6 was pulled. To confirm my theory I pulled the pan and found that no bottom end bearings had spun on their journal. There was more wear on the bearings than I would like, but not enough to explain oil pressure loss or bearing knock. The pickup tube however was almost completely plugged by metal debris. I cleaned the pickup screen out and thoroughly cleaned the pan for a second time. The knock still remained when I put the pan back on. I was not able to make the noise change by pulling any spark plug wire at this point. Which indicated to me that the problem is getting worse. I’ve been driving the truck with the noise for the past couple of days, but the noise is becoming more constant now, so I pulled the valve covers tonight. The noise was louder than I’ve ever heard it, and when using a mechanics stethoscope on each cam cap with the engine running the noise can very noticeably be heard coming from the cam cap between #6 intake and exhaust. I don’t know what I am dealing with here, so I’ve decided to source a used head instead of trying to fix this mess. I suspect the oil passages in the head may be plugged or perhaps that valve is sticking in the head. The rocker arms were removed from that cylinder and were in pristine shape. No flat spots and no hard spots in the roller. Whatever it is seems to be unique to my motor as I cannot find anyone describing a similar situation. I’m curious to hear what others think of my situation and if there’s any ideas out there
