4.0 Swap
Danger Ranger 4.0
Miles, Iowa
Hey guys, i was wondering if a 1992 ford 4.0 will fit in a 1998 ranger, both autos. The 1998 has vacuum hubs. Any Ideas or ex parts i will need from either?
you could get it to fit. pretty much you would have to use all the 98 sensors, the 92 flywheel considering its a 6bolt instead of 8 bolt. the 98 heads everything else up . its a returnless system and the 92 is returned.. basically the block and bottom end is what you could use from the 92.
