arineod
I have an 86 Bronco II 5sp 2.9L. What is the best year and type donor vehicle to get the 4.0 out of? I read some posts and the tech article and see that it is mainly the 1991-94 explorer or ranger for the easiest swap and that I should get the vehicle because of the computer and all the other items needed. I also hear things about an aerostar van as well.
I have a 4" sus lift and heard it is smart to throw on a body lift to get more space for the 4.0, is that a good idea? If so, is 2" good enough?
My bronco runs good right now except the valve cover gaskets are leaking causing smoke when you drive. Was sitting for a while. Won't drive it until that is fixed because I hear the heads crack easy. Truck runs great other than that. I plan to replace the valve cover gaskets with the ones that around $40-55, not sure what the part number was but I read it here on the forums and wrote it down.
Looks like there is a lot of stuff I will have to take off in order to get to the valve covers. Any pointers on that procedure? or a tech article. I'm not a mechanic but I can follow instructions and do minor maintenance with common sense.
I will probably get some more life out of the 2.9L at least until I get back from my next deployment (military). use time of when I get back to do the swap.
Thanks!
Thanks!
