Nova 404
- Mar 16, 2017
- Automatic
Anybody know were to find injector data for Ranger injectors? I have an 2003 FX4 with 4.0 Vin E that had originally a 0280156029 injector, engine blew a head gasket and I replaced the engine with a 2007 4.0 vin E. Long block is the same we all know this. When swapping the plastic tips came off a few injectors so since they had 250k on them I decided to replace them, I chose to get remanufactured 4 hole upgraded injectors off EBay (bad idea).These were a different color and all the numbers had been ground off of them(checking after the fact)Starts and runs awesome, sets P0171/P0174 every 4 days of driving. I checked on Snap On scanner and after clearing the adaptive learn and letting the car idle for 30 minutes the LTFT,s are in the mid 20's both banks which is not good. Contacted seller and he says they are correct upgraded replacements for my 0280156029 injectors. I spent last Sunday checking all systems on the truck and checking fuel pressure, vac leaks etc. and found no other problems. I had the 2007 injectors lying around( different style connector) part # 0280258055 and I bought wiring adapters to try them to see what they do to the LTFT's since I know for a fact they are a 4.0 injector and LTFT's are -1 to 2 (which is perfect) after a few days of driving. I have searched high an low on the web and cant find any info to compare the two, Mustang or Camaro lots of info out there. Has anybody swapped to later injectors? I have been going round and round with the seller trying to prove to him his injectors are WRONG
