4.0 SOHC first start idle 2 low
mred3
Gridley, CA.
New rebuilt engine installed at first start the engine wont idle can hold it running with the peddle but let it off it dies it throwing codes P0112 & P0102, checked the plug for the MAF sensor wasn't clicked all the way but that didn't help I don't believe I have any vac leaks.
Any ideas would be appreciated
Ed
Yes both codes would come from MAF wires not being connected, Air temp sensor is part of the MAF sensor on your year.
Vacuum leak would make idle high.
Fuel injected engines can't use an idle screw, no jets to meter fuel by air flow, so they all use an IAC(idle air control) Valve.
It will be on the upper intake where throttle plate is, it looks like an electric motor, because it is.
It opens a valve in an air passage that bypasses throttle plate, computer controls this motor.
Make sure wires got plugged back in.
Another thing is the ECT(engine coolant temp) sensor, computer uses this sensor to tell..........engine temp.
Cold engine needs more fuel and higher idle or it will stall, that is what the Choke plate did on carb engines, but again, no jets with EFI, so computer has to know engine temp to run engine in Choke Mode, then run it normally after engine warms up.
The engine should still have 2 temp devices in 2005 I think, one for the computer(ECT sensor) and one for the dash board gauge(ECT sender), Ford did combine them into one sensor around this time.
But 1 or 2 it/they will be on the thermostat housing, make sure they are plugged in
Yes it has 2 temp sensors, Will check on Thursday when I'm off work.
Thanks
Ed
TPS shouldn't cause a low idle, it can cause a No Start, and sluggish acceleration and/or lack of power.
And if TPS voltage was out of it's range, .7v to 4.9v then CEL would come on with code for that problem
A big enough vac leak can cause a no-start, or cause a stall after just a few second of running.
I saw a 4.6 once that would only run at WOT after a head gasket job. The parts store sent us the wrong intake gaskets and the guys working on it (this was in tech school) didn't catch the difference. It was leaking so bad it wouldn't run from being too lean.
Try resetting the computer. If it will run better at first then starts having issues again suspect the MAF. They can be damaged during removal, or they can just get crap over the opening. Both can cause your symptom.
Sending the wrong gasket would really suck, But I'm sure its not the case here since there just big oval seals. I've checked the PVC and lines, also put on a autozone IAC and the RPM went to 2k at start up and would not come down from that speed, think its a bad valve? you know it is autozone.
Thanks
ED
IAC Valve opens all the way for starting, then within a few seconds closes to set idle based on engine temp.
The colder the engine the higher the idle, above 1,500prm might not be unusual at 32degF.
Unplug IAC valve and it should close causing engine to stall.
Well ended up installing the original IAC back on and cleaning the MAF sensor then I took it for test drive it was missing on acceleration brought it back and pulled the plugs and found one of them was black they were new plugs, so I decided to put new set in. After that it sounded the best it had yet idling with just a little tiny bit of hesitation, so went for another test drive made it 2 blocks down the road and the power wasn't there so I decided to turn around and the engine died would not restart so towed back to house. Decided it was a fuel problem so not having a fuel pressure gauge to fit the rail I stuck a small Philips in the valve with ignition on and it had nothing hardly any fuel coming, going back before first start I bleed this way and fuel blasted out so now it seems the pump has took a crap, I did change relay for pump, then I pulled the front fuel filter line turned key on and it came out really slow no pressure at all I would think it should shoot all over right? New fuel filter was installed the day the engine originally took a crap in November.
Thanks
Ed
The first indication that I had for a bad pump was low idle on first start. After about a year, it then went to no start!!!
Removed the bed for fuel pump test/replacement have 10.9 volts at plug at fuel pump, turned on with hose disconnected it put a small weak looking 4 or five inch stream of fuel out I'm sure if was putting out 70-80psi it would shoot quite a bit more than that so I found a spectrum pump at napa for $288.00 and another place sells airtex for $240.00 but have heard a few people say airtex are crap never heard of spectrum. Anybody have any recommendations?
By the way the bed removal was 10 times easier than I thought, because the last time I changed the pump I did from below wont do that again!
Voltage at pump should be battery voltage, it is a direct wire connection to battery when activated.
So check battery voltage with the same meter.
Fuel Pump(FP) Power path is:
Battery"+"----FP fuse(20amp)-----FP Relay----------inertia switch(in cab)--------Fuel pump-----ground(in cab or on frame rail)
FP fuse and FP relay are both in engine fuse box
I would start at battery end and check voltage along the pathway to see where it drops.
The "flow" from the pump seems OK, the "pressure" is from the fuel injector restriction, so is back pressure, and that could only be tested if you attached a pressure gauge to the fuel pump hose.
I.E. oil pumps don't put out 30psi of pressure, they have variable "flow", engine RPM, oil pressure comes from the small gaps at the bearings and oil passages, as long as the flow into the system is more than than the flow out there will be back pressure, and that back pressure is what you see on an oil pressure gauge, or a fuel pressure gauge.
If you could find the Liters Per Hour(lph) specs on the pump then you could run the pump for a minute and see if it pumped out 1/60th of that spec.
I think Returnless spec was 100lph, so over a liter a minute should pump out(1.5l), and by your description that is happening.
The older Return line system fuel pumps were 60lph I think.
But the low voltage is my concern, was that with pump connected or just testing the wires without the pump?
If without the pump running then voltage could drop down below 6volts which would not pump much if at all.
Have pump on now have filter off its pumping less then the old one
