4.0 SOHC cruise issues
gw33gp
Ham Radio Operator
Costa Mesa, CA
CA - USA
Other
2004 Bronco Badlands
Vehicle
Drive
1.5"
33"
On a recent trip my 4.0 SOHC started doing some strange things when trying to maintain a constant speed. If I let up to slow a little it was like shutting off the engine. Then when I stepped on the gas pedal to gain speed it would not do anything until I stepped a little harder and it would surge forward. Once, I floored it to make a pass and the engine just booged down. I had been driving for a long distance when this happened. I needed to get gas, so I pulled off to fill up. It was difficult to drive on the streets. When I pulled up to the pump I pushed in on the clutch and the engine died. I filled up and checked under the hood to see if any vacuum hoses were loose or the PCV valve was secure. I disconnected the MAF connector and reconnected to make sure it was getting good contact. When I went to start it, it fired right up and had no further issues until about another 600 miles it started doing it again and went away on its own.
I considered the IAC but thought that would just create an idle issue. Could it be causing throttle control issues at higher rpm?
I had an issue after another fill up where the rpm hung a little high while shifting and when I stepped on the gas pedal to accelerate after shifting it would not go until I stepped down a little more, it surged forward again. It cleared again after that, and I had no more issues for the rest of the trip home.
Is there anything else that could be causing it? I plan to use dielectric grease on the MAF connector to reduce any corrosion on the contact pins that may cause a bad contact.
How old are the sparkplugs? How old is the fuel filter? Any serious sensor issue should turn the check engine light on. Did you happen to get a batch of bad fuel at the station?
600 miles? Sure you weren't just out of gas? LOL
Seriously tho. It does sound like an intermittent vacuum leak or bad gas.
The intermittent nature of this will make it tough to diagnose. But there could be clues...
Does it start acting up only after getting near empty?
Have you checked fuel pressure when it starts acting up?
You might want to connect a scan tool and monitor some live data as you drive.
I know this is a high mile rig... has it ever had the fuel pump replaced?
I agree with the others.
First thought was a vacuum leak. I’ve had similar issues before that were caused by a crack in the upper intake manifold (plastic)
I’ve also had similar issues caused by a weak fuel pump, clogged fuel filter, and bad wiring going to the pump.
I have a fuel pressure gauge, so I would probably check that first.
I’m leaning more towards a vacuum issue.
