ok guys, im going to throw my clues and see if anyone can help me, i sure need it.
today she suddenly got spuddery, threw in some super unleaded and some marvels mystery oil. thought i may have bad gas. got up to speed a while and turned back for home as it was getting worse. halfway home it got better, lasted about ten minutes and went bad again. a guy at the store heard it and said bad cats, the muffler shop drilled holes in the pipe and said cats flowing.
she blows black then gray smoke when she spudders. wanting to stall more now.
ok so i go to oreillys to pull codes, this is what i got.
koeo
codes: 159 ????
998 hard fault present FMEM mode
memory 121 closed throttle voltage lower or not same as MAF
157 MAF below max voltage
158 MAF above max voltage
556 fuel pump relay primary circuit failure
then i got these for KOER:
411 cannot control rpm low
412 cannot control rpm high
im going to clean my MAF and figure out which is the IAC and clean it too.
ill come back and check here in a bit
koeo
codes: 159 ????
