4.0 problems
Micky123
I have a 99 ranger 4.0 liter. It starts and runs but misses like crazy. I've put new plugs in new wires and coil pack. When you pull plug wires off of it while it is running it seems like none of the cylinders on the driverside (bank 2) are running. I took the breather off of the intake tube and sprayed a little brake clean in while idling and it smooths out. So it seems fuel realated. It has 64psi of fuel pressure and the injectors are working. I pulled them out and checked them and they are spraying. Any suggestions?
Thanks,
Michael
