stranger96
Since there is only a few things about turbo 4.0's I am here asking for help.
I have a junkyard 4.0 ohv with 115k on it I plan on replacing all the gaskets including heady duty head gaskets and bolts/studs. Since I am turboing A cam is not absolutely necessary and also adds a lot of money especially with the 422. I may do the 410 just because.
I plan on running an intercooled system using a turbo off a 4bt cummins.
SOHC Maf and 24lbs injectors, upgraded fuel pump. WIdeband AFR
What I need help with is what tuning to use with this set up I have looked into Delta force tuning I am also considering megasquirt but I want to be able to still pass emissions. Suggestions and other things would be helpful thank you!
