ABNRanger
- May 12, 2008
- Age
- 39
- Automatic
Hello and thanks for reading! I've browsed the forums and have seen about 16 or so missfire situations on the 4.0L V6 engines and I'm about at wits end as to why mine keeps doing it. I first noticed it when i would pull up to a stop sign, the truck would almost lurch back and forth. I replaced the plugs and wires as well as filter, oil and tranny fluid thinking it could be that. It still did it. I replaced the plugs again, the coil pack and the #2 Injector (BTW, it threw a p0302, cylinder #2 Missfire code and CEL). With the injector changed, it stoped for about 30 mins. Then started again. I've rechecked everything and still nothing comes to mind. I've heard about the possibility of it being a leaky intake man, but wouldn't that cause it to miss in more then one cylinder? Any help will be greatly appreciated. Also, I've cleaned the MAF and ran injector cleaner through it about 4 times.
