96ranger96
- Oct 12, 2014
I've read through a lot of forums and have done some suggestions but now I'm at a total loss. First off the truck was running fine. It started running a bit warm ( not even 3/4 on the guage but warmer then usual) so I let the truck idle for a few min to see if it would get any higher. It never did but then all of a sudden the truck started shuttering and then died. Started right back up and that was that. Decided to change the thermostat and run a can of sea foam threw it. Ran fine for a a day then it died again. Then it got to the point where it would idle till it got hot then shutter then die. Would not restart hot. Once cooled it would start right up. Then I developed a miss. Changed iac, cam positioning sensor, plugs and wires are newer. After changing cmp it would start up cold or hot but miss was worse. It wouldnt stay running unless I gave it gas which it would smooth out. So progressively got worse so I was going to check out maf. Found out previous owner put it on backwards. Flipped it around and now its running worse! It starts up fine then goes into a lope like I have a cam in it. If I rev it sometimes with will sputter up then other times it struggles to stay running and dies. It lopes so bad the truck shakes back and forth and it will drop to 100rpm añd somehow sometimes still come back. I just don't know where else to go from here cause everything I've done has been making it worse. Please anyone with suggestions. It's a 96 ranger 4wd with the 4.0 in it. It has a multi misfire code, rev per min code, and bank 1 and 2 running lean. It has high flow cats on it but that's it.
