4.0 fuel mileage readings
1986fordranger
central VT
hi . i recently bought a 1999 ford ranger XLT 4x4 automatic extra cab with the bigger 4.0l v6 . also is pretty low mileage at alittle over 92,854 as of current . also has abit under sized tires (225/75r16) . the truck should have 245/75r16's . now this is my question driveing in country/city driveing im getting roughly 20 mpg (miles per gallon of gas) . seems pretty decent in my opinion . the question is are the smaller tires messing with my gas mileage readings ? . in theory i was thinking the smaller tires mean it takes more revolutions of the tires to go the same distance as the stock sized tires . whitch would mean im going more miles down the road then the trip odometer reads . true or false ? . any opinions on this topic would be great . thanks
Yep. Your speedometer is gonna read high and you'll rack up some extra miles on the odometer. Not sure exactly how much, you'd have to do the math. tirerack.com is a good place to look up tire specs. Most of the tires have the revs per mile listed in the spec section.
By using the the (225/75r16) instead of the factory (245/75r16) , you are gaining 4% more mileage on your odometer than you actually are traveling. So if you are getting 20mpg, take away the added 4% and you are actually getting 19.2mpg. That is pretty much what I get with my stock tires.
