Welcome to TRS
So it starts with 50/50 test, but stalls when it runs out of manually added fuel
In 1995 and up, that means computer is starting spark but not injectors(assuming fuel pressure of 30psi)
When you turn on the key the CEL(check engine light) should come on
When you start to crank the engine the CEL should go OFF, that means computer is "seeing" a good timing pulse, which should be happening if you have spark timing
Unplug the TPS(throttle position sensor), it has a 3 wire connector
Then try starting
If it starts then TPS is shorted out, telling computer to shut off injectors, to "Clear a Flooded Engine"
If still a no start, then assuming good fuel pressure, its most likely a computer issue
You can check CAM sensor, unplug its 3 wire connector and try to start, but I think only the 3.0l engine needed working cam sensor to start, and only a few years had that
