come on guys someone must know the specifics of this 4.0 code reading
im all done with change over 2.9 to 4.0 have it running but it slowly heats up
done all the normal test checked for craked heads (pressure test)using 4.0 radiator.has been bleed for air,im stumped!
any help would be appreciated. the cde again is 327
thanks
i guess what im asking is would this problem or code cause overheating.
i put it on the road first time with 4.0 motor and its running hot about 220 f
when i got home about ten miles. ive done a pressure test looking for blown or cracked heads no leaks so what next to check.
For
