sytherstrike
Today I was going down the free way and pushed the gas, it felt like I hit neutral, as soon as I let off the gas it went back into od and when I eased into the throttle it started acting normal again. I then got off the freeway and when I stopped at the light at the end of the off ramp, nothing nadda no go. I shut the truck off put on my 4 ways. I waited about 15 minutes and decide to try one more time before calling a tow truck. So it hesitated but went into gear and shifted through all gears with slight hesitation in each one. I than did a trans flush and fill, just to see. I do the flush and fill and the hesitation is almost gone, but I have to manually shift into od. Its weird cause I can start in normal drive no problems shift up to third no issues, and then manually put it in od and its all good, but if I put it in od to start its like its in neutral. I figure my trans is prolly toast and needs a rebuild anyways, but it just seems so weird I've never had a trans act like this before. Do you guys have any ideas on whats wrong or could cause this?
