92ranger18
Will a 302 dual sump oil pan fit a 351w and can i use the 302 oil pickup? Exactly how much wider is a 351 than a 302. Can i make some spacers to go between the intake and heads so i can use one of my 302 intakes?
No the pans will not interchange. The 351 is about 1 1/2" wider. I would just get a 351 intake because it would be a lot less hassle.
years ago I had a friend take a 351 oil pan, bolt it to the engine (to keep its shape), cut the bottom off, and weld the bottom portion of a 302 dual sump oil pan to it. but he was sticking it into a 1965 fairlane wagon that had a 289.
he was what you could call an "appalaichan-american"
