I wouldn't use 302 anything on a 351.
They are the same block, but that's about it.
From what I remember correctly 351 ranger had a set of homebrew log style manifolds on his. I have seen plenty of manifolds that work.
For the record, it's not the same block...
Not to sure on how they will fit but if you are going to try to make any power with that engine I wouldn't use them. Second I'm not too sure about the amount of room around the spark plugs with those manifolds either. Being that you have a 2wd you will have some room look into a set of decent headers. Performace Products will have a set that will fit in a 2wd.
Matt
no not so they are both from the windsor block family. the only differance is a 351 as a bigger stroke, taller deck, and a bigger oil pump.![]()
