Frankenbronco
- Jan 29, 2013
- '89
I have an '89 BII & an '80 F-250 3/4 ton 4x4 w/ rebuilt 351m, bad tranny. I want to pull the motor, tranny & transfer case out of the 250 & stick it in the BII. The motor has a 2 barrel carb with mechanical fuel pump. The BII already has a 3" body lift. I was going to get a wiring harness from either painless or summit racing. The questions: Where can I get motor mounts? What all needs to be cut or removed in the engine compartment? Am I going to need to reinforce the front end for the weight of the new motor? Thanks for your help.
